Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: properly tuned 9b car with cats
    i see this stuff every day and forget to share. so im sharing... here it is.
    take a totally stock 175K 1st gen.. ALL STOCK. add injectors, afc, hot wire, manual boost control... done. makes great power!
  2. The Following 7 Users Say Thank You to Ray Pampena For This Useful Post:
  3. #2
    hax!
    Actually I'm not totally surprised at the HP numbers. The torque numbers are really good though; did not expect that at all. What boost is this at and what size injectors?
  4. #3
    hax!
    This, I have an AEM series 2 that I am waiting to install with DR700 or DR750, but if there is some substantial gain to be had with just 9b's, I may have to just install it tune it with the 9b's then tune again later when and if I get gibber snails
  5. #4
    About 17psi then falls to 11. I wouldn't leave 9bs on that build!
  6. #5
    "Gibber" snails, huh?
    I thought yours had 13Gs - part of your stage 4 pkg?
  7. #6
    I said I don't know what snails I had IF it was 13g then stage 5
  8. #7
    Quote Originally Posted by Ray Pampena View Post
    Would have no intentions of leaving 9bs, had not intentions of even installing my goodies with 9bs until I read your post.
  9. #8
    Oh - mis-remembered, then, or mis-read the Hennesey stuff you sent me.
  10. #9
    Great numbers, is this on pump?
    - 2fnloud - there are very big gains to be had from the AEM alone if you, or someone you know can properly tune it. It is a very great tool to have. You can also shed a few pounds from all the crap you dont need once its installed.
    And the list goes on...
  11. #10
    that's an easy 50whp gain over stock. still, you can see that the 9b's are hold the car back.
