Got the boost solenoid vacum lines unpluged...
And cant in love of god remember how they were before.
Is there a thread or picture that can help ??
Thank You !!!
RealMcCoy already gave a great example... here are some pictures that I took from my car
To help a little bit, started on the back left working my way to the right.
Top- white stipped hose goes to pre-turbo pipe
bottom- Connects to a double t connector
Top- line goes somewhere under the EGR valve
Bottom- red strip hose that connects to the metal vacuum tube hold on the TB
The top vertical one - left is the blue stripe hose, the right is a solid black hose
The bottom vertical one- left is the green stripe hose, the right is yellow stripe hose
Hopefully these help you some the second one is where the T-connector is (below the yellow stripe hose near the clamp):
This helps alot!
I know this has been answered, but a lot of people forget there is a hose diagram right on the underside of the hood. On the older cars it might be worn off, but it should be there and it's not that hard to read/understand![]()
