Check fuses, check for +12v at fan motor when ignition is on. If you have +12v, problem is with the switching/earth circuit.
Earth fan motor, it should go. Earth pin 3 of relays, if fans work then earth at the control module.
When earthing, do so with a filament testlight so you dont blow fuses/components
Hardly going to be the resistor as its only connected when the fans on low speed, on high speed its bypassed.
