Results 1 to 10 of 11
Thread: fan help
    Forum User Not Verified Feedback Score 1 (100%) ntcmpjg's Avatar
    Bamberg, Germany
    fan help
    I tested the fan and it turns on when hooked to direct power. but when it gets hot it doesn't do anything. I tested the temp sensor on the water neck housing works fine. WTF am I am I missing? I also replaced the HOGH Fan relay didn't do anything
    3000GT of Europe
    www.3sofeu.org/main
    Cherry Hill Mitsubishi Coupon Code- 3SE
    Forum User Not Verified Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    What year car?
    Do the fans come on when you turn on the A/C?
    Bamberg, Germany
    What year car?
    The one does the other nothing. Its a 94 NA
    Medford OR
    Quote Originally Posted by ntcmpjg View Post
    Which one comes on?
    Bamberg, Germany
    Which one comes on?
    The little AC fan comes on only. When I put power to the big one it works fine. I think I might just hook it to something that turns on when the car does so it just stays on
    Medford OR
    Check the ground(G101 at the right front fender)
    You have a datalogger?
    Warner Robins, GA
    While the N/A fan wiring/control might be different from the TT, I doubt it. And the main cooling fan (larger fan on the passenger side) is controlled on the ground side. This means there is supposed to be +12V at the fan whenever the key is on. The fan is turned on and off by closing the fan's ground. I suggest finding out why there is no voltage at the fan when the key is on. And if the fan runs when you put +12V to the fan and the coolant is cold, then there may be another wiring problem. With the engine cold, the ground side of the fan should not be connected. First thing I'd check are all the fuses.
    May 2011
    na, dont waste timing hunting for that ghost, wire the fan to turn on, it will save you a headache
    Bamberg, Germany
    Quote Originally Posted by mtpockets20 View Post
    And normally I would but it only has 71k on the clock and i want to track it down to keep the harness intact
    94 3500gt vr2? verified Feedback Score 9 (100%) n2nsanity's Avatar
    NC
    u try swapping out the resistor yet?
    u know i have at least 1 or 2 extras, lol
