Results 21 to 30 of 31
Thread: Shifter
    Since Bob's was impossible to get when I got mine, I ended up getting the Seattle SS. I love it, and it has been solid with no issues. 3sx had em...
    Yeah, seattles shifter is awesome, "great" welds. (Sarcasm)
    Sent from my DROIDX using Tapatalk
    STL3S Not Verified
    Oct 2005
    You should sell your own custom "Forest Gump Super Vice Grip Race Pro Shifter". Makes a 12.1 pass a cinch!
    Wait, Forrest, your shifter welds broke?
    You never mentioned that at NG
  4. #24
    yeah first pass down the strip I reached for 3rd and nothing, the shifter was in my hand, snapped off at the point where the rod welds to the assembly on top. Basically no weld, 99% powdercoat. I'll post some pics later. Ran one complete pass with a vice grip shifter for the night @ 12.1 @111. I checked my map again and I was pulling 4 degrees of timing and only 14 PSI. Was going to inch it up over the night, but didn't want to keep trying to shift fast on the vice grips and hurt the trans. At least I know the 2 step rev limit is AWESOME. Only had it set at 4500 and -10 degrees of timing, ran a 1.75 60FT 2nd pass barely trying. If I had a chance to up the revs it would've gone 1.6x easily if nothing broke.
    going back to stock and re-welding the seattle to sell probably.
  5. #25
    I can't imagine the plethora of thoughts that were going on in your head at this moment in your life.
  6. #26
    After you weld it, it shouldn't be an issue....should it?
  7. #27
    no, I'll weld it stronger than its ever been. I've just been debating going back to stock anyway, so I'm going to run around on stock for a week and see how I like it.
  8. #28
    lol, main thing was just keeping enough momentum to make the turn off the track and get out of everyone's way.
  9. #29
    I'm going to post this up for anyone who is interested in the fitment of the 93+ shifter on the earlier 1st gen years. I finally got around to swapping everything out today, & managed to snap a few pictures along the way.
    93+ assembly installed without the slightest issue into my '92 vr4.
    Comparison between the two shift arms:
    The 93+ arm simply won't work with the 91-92 base. To make the comparison easier, the 93+ base has the solid bushings installed.
    Here's the 93+ for comparison:
  10. The Following User Says Thank You to mb3000 For This Useful Post:
  11. #30
    Difference in height between the bases:
    And the different part #'s
    Early years:
  12. The Following User Says Thank You to mb3000 For This Useful Post:
