Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Fuel trims maxed lean
    Cazenovia, NY
    As the title states, my trims are all maxed lean on the logger.
    Lo=136%
    mid=133%
    hi=140%
    Doesn't matter how I adjust the MAFT. -10 or +20 mainscale, trims still stay the same.
    I believe I read somewhere awhile ago that adjusting the fuel delivery wont adjust trims due to the MAFT being RPM based and not load based?
    Any info on my dilemma? I really want to get these trims close to 100% before I start dealing with WOT.
    Cazenovia, NY
    No one? I figured this was a pretty common occurrence.
    The trims won't readjust right away. You need to log your O2 feedback to see what the ecu is doing with the fuel at any specific moment in time. You can then use that information to see if you are on the right path to correcting it. Sounds like you may have a fuel delivery issue though. It could be a weak fuel pump.
    Cazenovia, NY
    Thanks for that. Tomorrow I'm going to see what happens if I increase my fuel pressure. I know FP doesn't adjust trims directly, but indirectly it can fix them.
    Cazenovia, NY
    Well, I put the FPR back at stock pressure, just so I can deal with my problem at hand (My gauge at least says 43.5 with vac line off, hopefully it's accurate).
    Any clue why the car runs 120% better with the Gen II on the GM 3.5" setting, instead of the 3.0", which is what my car has? On the 3.0" setting, the wideband reads pegged lean at idle. The moment I switch to 3.5", the fuel richens up (a tad bit too rich) to around 12-13 and the idle is smooth as can be.
    Mid fuel trim went down a whole 2-3%, with others still maxed out.
    VR-3747 :D Not Verified
    Dayton Ohio
    are you sure that your have your injector size set correctly? its easy to screw up...
    i have a 3.75" z06 maf on mine, but i am running my maf-t on 3.5 because it responded better... maybe the 3.5 setting is the one that generally works the best? not sure about that though.
    just make sure you didnt make a foolish mistake. if you wanna rule out your maf-t as the issue, you can unplug it and the car should start and idle fine, but with no maf signal it will throw a code and run in limp mode (pig rich). if it does run rich, that means its not a fuel issue (its a maf-t issue). if there is no change it is obviously not the maf-t.
    I have a maft and a 3.5". With my 550cc inj and it set to 550cc it ran REALLY lean. They had to add about 10% on the trims to make it run good. Pampena said the maft just likes to make the system run leaner than normal.
    Maft was used for translation, safc was used for tuning. The rpm Wire on the maft was left disconnected because it doesn't need to see rpm for injector adjustment
    [Droid X via Tapatalk]
    Dayton Ohio
    i agree with keyan, and thats exactly what i have done... mine is set for 550's and zero'd out
    Cazenovia, NY
    I'll try that out today. I find that there is such a huge window between the 3.0 and 3.5 setting. 3.0 makes me run lean as hell. I have to correct some god awful amount to even get the o2 trim to get anywhere near 100%. I also have to increase fuel pressure by a ton, which I don't like.
    The 3.5 setting makes me run crazy rich. I have to take out so much fuel that it obviously isn't right. I'm on stock injectors.
    Quote Originally Posted by Keyan View Post
    You must have the original MAFT I take it. I have the Gen II, so no need for a SAFC.
    Cazenovia, NY
    What do you mean "set" for 550? There isn't a spot to specify what injectors you have.
