Results 1 to 4 of 4
Thread: Possible IAC, ECU or EMU tuning issue?
    Forum User verified Feedback Score 1 (100%) Monster Stealth's Avatar
    Fort Wayne, IN
    I am having an issue where after initial startup my car will fall flat on its face and die after about 20 seconds of idling. I can keep it running if I keep my foot on the gas. As far as I am aware the ECU and IAC are original. I currently am running the EMU in stage 3 with e85. Any help or input would be appreciated.
    9B+93-13.2@108
    16G+E85...?
    the cake is a lie
    Fowlerville, MI
    Cold start or hot start or both? Does it just lean out to the point where it dies?
    Fort Wayne, IN
    I have not forced it to stay running long enough to reach operating temp. So I can only confirm it does it on cold starts. I have left the key in the on position to (correct me if I am wrong) heat the wideband and narrow band o2 sensors up so they are reading accurate right away. Every time it falls flat and dies the AF is sweeping slowly from 11:1 to ~13.5:1 where it then dies(these are gas AFR's running on E85 fyi).
    Off topic: This has been sitting in my garage for quite some time, and I had a new garage door today which forced me to fire her up and has really gotten me motivated to get this car running and tuned.
    Fort Wayne, IN
    I pulled the IAC tonight. Resistance across all appropriate pins were in spec, but when I applied 9v to pins 2/5 (+), and 3/6 (-) I had no movement of the stepper motor.
