Cant find them anywhere, checked Stealth 316 too. Anyone got a link or know the specs for all the bolts on all the motor mounts?
The 2 sides im guessing are around 65, and the front and rear are about 40
This is based on the typical 14mm and 17mm head size. its really not that critical, just make sure they are good-n-tight
You dont want to know my guesses. I would have twisted those heads off for sure. lol. Thanks man. Id like to know the actual spec regardless, pet peeve of mine.
drivers side 17's are 80...........
trans mount main bolt/nut is 51............
trans mount fender wells are 33..........
front and rear bolt/nuts are 40.......
drivers side main bolt/nut is 51.........
drivers side 14mm stays are 25............
so like i said, good-n-tight![]()
