Results 1 to 4 of 4
Thread: Looking for....
    Monogamous Gigolo verified Feedback Score 8 (100%) 2fnloud's Avatar
    Looking for....
    The wire harness in the hatch that contains the reverse lights. I think it is the one in the center at the bottom of the rear wall of the car.
    Anyone know for sure, or know what color the wires are for the reverse lights?
    Thank you for your help,
    Forum User Not Verified Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    The diagram says the wire from the switch to the bulbs is red/blue, and the wire from the bulbs to ground is black.(G407, at the center rear of trunk)
    I will check that out tomorrow thank you,
    Just so I make sure I get this correct both the red w/ blue strip and black will be center rear of the trunk....right?
    Medford OR
    No, that's the location given for the ground (G407). THe red/blue will come from the body harness, and have a splice were it splits into two wires going to the individual lamps. I assume the two ground wires will splice into one in the same area. You should be able to figure out where it splits by looking at the harness.
