Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Stock Oil Pressure gauge readings...
    Have the NEED 4 SPEED.. verified Feedback Score 0 IronmanTT's Avatar
    North Texas
    What does a stock oil pressure gauge read on a all stock TT? Mine is showing a constant 3 notches from the bottom. Seem kinda low but no lights cooling temp is running cool as well. Just need to confirm all is OK ...
    I'm meaning right at this mark...
    3s Less Forever hate to say it...not going to get sucked in again..
    Rochester, NY
    A bit difficult to tell you it's safe since they're only notches. I can tell you mine used to hang out around there at warm-idle before I spun a bearing. After the rebuild it's above half at warm-idle.
    Best to take the time to check it with a mechanical oil gauge, only have to do it once, but I would imagine it's just normal.
    Forum User Not Verified Feedback Score 0 Keyan's Avatar
    Warm idle mine hangs at 1 notch or half notch and it has for the 70000 miles I've owned it.
    Every car is different.
    [Droid X via Tapatalk]
    Mine would hang out at around 1.5 to 2 notches at warm-idle. While cruising at 2k RPM it would be around the big notch in the middle-ish. If I ever had it above that in revs I wasn't just cruising so I wasn't focusing on it, just glancing to make sure it hadn't dropped to the bottom.
    DocHoliday
    Guest
    I don't have a TT, but mine is always in the 3/4 range of the gauge.
    Administrator Feedback Score 3 (100%) Alan92RTTT's Avatar
    Madison Heights, Mi
    Mine was 1-2 up from the bottom on warm idle.
    It would bottom out on hot idle.
    I Installed a cheap manual gauge. I get 12.5~ on warm idle. I do not trust the stock gauge.
    Not A DSM verified Feedback Score 3 (100%) Polygon's Avatar
    June 2006
    Utah
    Quote Originally Posted by Alan92RTTT View Post
    Mine is the same way. It doesn't quite bottom out, but close. I don't trust that ANY of the stock gauges are accurate. Especially the oil pressure and boost. First two gauges I would replace.
    Forum User Feedback Score 1 (100%) IcelandGTO's Avatar
    Iceland / Europe
    this is my oil pressure while cruising.. I Never see the gauge show more then1/3
    Its 1-2 up from the bottom on warm idle
    While cruising at 3k RPM it would be around the big notch in the middle-ish
    94 SL | 96 SL | 91 R/T | 93 SL | 94 ES | 95 SL | 92 VR-4 | 91 SL | 93 ES < gone | curent > 95 VR-4
    ............................ AUGUST 2010 RIDE OF THE MONTH !!
    ................................... 2010 RIDE OF THE YEAR !!
    i've yet to hear of any 3/s with a stock (100% unmolested) oil pressure gauge that consistently ran "in the range" on the gauge during normal conditions. my car has never been above the 3rd-4th mark; either n/a or TT. seems rather useless as a range of indication--if you ask me.
    i'm with polygon. stock boost & oil pressure gauges are SHIT. don't rely on them.
    Iceland / Europe
