Going on that flywheel that pops up every once in a blue moon (the chromoly one Lehkume and Spalsbury came up with). Not sure if anyone knew that flywheel was a 7" Evo adapted flywheel so we can bolt on any EVO clutch. Well, TMZ builds a badass twin disc that's much beefier than any clutch I've seen out there besides the Giken.
I was going to go with the Tilton OT-2 but this CM clutchpack fits a Tilton OT-2 clutch and pp.
Basically $400 for what you see here. All you need is the flywheel, clutch plate, pressure plate, and HTOB (since the stock fork will not fit without being modified due to the geometry requirements).
TMZ Performance
No more stripped output shafts since it pretty much contacts the entire tooth area![]()
