new idea! how many turns do you have your sas/throttle stop screw set at?
ive tried a new iac, new tps, dashpot, pressure test(did have some bubbles comming from under the tps but, very minimal) and, still dies when clutch depressed. i had this prob before and was easy fix when i adjusted the dashpot on my stocker(tb). now when i push in the clutch the dashpot catches it at 1500 and brings it to 1k, a half second later the rpms drop to 200 and she dies 90% of the time or, catches it and goes back to 1k.
idles great, starts great, tps is 14-91(the best i could get). i followed the stock sas adjustment with the .25mm shim and 1 1/4 turn thing but, this is aftermarket with no info.
others seem to have this running good but, i miss my stocker. i tracked down a new stocker from japan and will be going back if not fixed before it gets here(1 week).
sad man!
