Results 1 to 8 of 8
Thread: AEM EMS serial gauges
    One fix at a time verified
    Kansas
    I have two AEM serial gauges I never used although I'm sure someone used them in the past. It comes with everything you need.
    From AEM's website:
    WHAT IT DOES
    AEM’s Serial Gauge plugs into our Series2 or Series 1 EMS giving you the ability to read up to 19 channels simultaniously. Now you can read boost, AFR, EGT, H20 Temp, IAT, RPM MPH and more on one gauge with an easy to read, digital LED interface. You can link multiple Serial Gauges together to divide your reading across several gauges.
    WHY YOU WANT ONE
    The Serial Gauge includes a user-selectable LED display allowing users to set vehicle specific limits, warnings, display ranges and operating ranges. This unit runs the standard EMS datastream by default, and includes 12 preset channels and seven user-selectable channels that are custom-configurable through the PC interface, allowing you to monitor practically anything attached to a sensor. AEM’s Serial Gauge includes user-programmable MIN/MAX storage for EVERY channel and records MIN/MAX values even if you are not using the function—if it’s in the stream the gauge records it. Red, yellow and green LEDs and the center three-digit display are fully user-programmable as well, making this a truly custom configurable unit. Users can set alarms for each channel so that when the signal exceeds a value the Gauge notifies you by flashing all LEDs and switching to the channel where the value was exceeded. User-selectable qualifiers eliminate false warning lights, and the unit includes two outputs to trigger ancillary warning lights based on user selectable conditions. The Serial Gauge also includes user-selectable alarm priority in the event multiple alarms sound, allowing you to set alarm readouts in your order of priority.
    AEM’s Serial Gauge includes interchangeable silver and black bezels and pin guides, and black and white faces for a customizable look. Quick-Connect technology allows you to install the gauge and connect the wiring separately for easy installation and less chance of damage to the circuit board. The Serial Gauge includes a harness, wiring to connect to the EMS, a daisy-chain adapter for linking multiple gauges to one EMS and software for a trouble-free installation.
    PRODUCT FEATURES
    Monitor 19 channels simultaneously—it’s like having 19 gauges in one!
    Works with AEM Programmable Engine Management Systems Only
    All necessary hardware and software included for installation
    User-programmable datastream channels (PC interface)
    User-programmable MIN/MAX values for every channel (PC interface)
    Includes two input buttons for scrolling through displayed channels and for clearing MIN/MAX values
    24 user-programmable LEDs and three-digit center display (PC interface)
    User-selectable alarm values include qualifiers to eliminate false warnings
    User-selectable alarm priorities in the event multiple alarms are triggered
    Two outputs included to trigger ancillary warning lights or other devices (lights not included)
    Silver and black bezels and pin guides, and black and white faceplates included for creating custom look
    Quick-Connect technology eases installation
    Standard 52mm gauge housing fits in most pods and can be remotely mounted virtually anywhere
    I'm asking $150 plus shipping each.
    So...I'd have to have the AEM EMS right?
    Kansas
    Quote Originally Posted by swoosh641 View Post
    Yes they'll only work with the AEM EMS v1 or v2.
    PM sent
    Kansas
    Quote Originally Posted by StealthyStu View Post
    PM sent
    Replied.
    Kansas
    Kansas
    Pics added.
    Kansas
