Was doing some tuning and threw this cell 'barometric pressure sensor' I know for a fact the MAF is good. The code will not clear. What can it be? PMs.
The baro sensor is built into the MAF so I don't think it could be anything else. IIRC it operates off 5V and sends data back directly to the ECU. If you check your service manual it will show you how to test the MAF and wiring to the MAF.
When you say it does not clear does it come back the moment you start the car [after you have disconnected the battery]?
Also read this as I went through a similar issues [was due to using the wrong MAF].
http://www.3sgto.org/f13/understandi...mbers-344.html
Waiting install
Build Thread
