Results 1 to 8 of 8
Thread: oil light is flickering on and off????
    Pueblo, CO
    the little genie lamp is flickering on and off on my vr4. just started doing this. I checked my oil levels and they were about halfway between the notches and put some oil to thetop of the second notch. still flickering. not seeing any smoke, or burnt oil smell or anything. car is running like normal, oil pressure is at about 20psi idle and 40-60psi driving. Thats how it has always been since forever. Anyone know why this light is doing this? its not steadily on, just intermittently.
    July 2005
    Arkansas
    If you have a real oil pressure gauge, which it sounds like you do, and the light is flicking but you have good pressure, its most likely the sensor for low oil pressure going out.
    Edit: Just read your mod list, and you do have a real gauge, 99% chance its a bad pressure sensor for the light
    Pueblo, CO
    right on, thats what i was thinking. i have another oil pressure sending unit too, maybe ill swap it out. Where is the sensor located for that particular sensor? Hmm, maybe have to crack the manuels out lol.
    July 2005
    Arkansas
    It's right next to the stock oil pressure gauge sendor. Back side of the block, right above the driver side front axle.
    One fix at a time verified
    Kansas
    Make sure the connector isn't loose going to the sending unit. I've had that happen before where it wasn't make a solid connection and would flicker.
    Feb 2011
    DFW, TX
    Same. Loose harness will cause it to mess up. Sensor replacement is easy too.
    Texas
    If it goes to ground, the light comes on. Just saying.
    July 2005
    Arkansas
    Good point, has happened to me as well.
