Results 1 to 4 of 4
Thread: fuel upgrade questions
    the BOSS of jellow supporter Feedback Score 0 a2j's Avatar
    May 2005
    Dairyland
    just gathering some info
    I changed my mind about using -10an fuel line. I will be running -8an. with two (more likely 340lph) fuel pumps. 720cc injectors or larger. e85 gas (obviously)
    questions:
    1. should I do dual feed to fuel rails? or 3sx loop should be enough?
    2. do I need radiator/cooler to cool the fuel that goes back in the tank?
    thank you for your input.
    1)I wouuld suggest running dual feed, especially if you feel you need a -8 feed line. It will be better at keeping even fuel to all the inectors.
    2) you will have no need for a fuel cooler in the return, two inline pumps wont heat up the gas enough.
    And the list goes on...
    Austin, what is your fuel setup? If you don't mind me asking.
    May 2005
    Dairyland
    it will be two in-tank pumps. I was thinking they would be heating up gas in the tank.
