^ Paul did you end up getting the AEM wideband working correctly with this unit? Keep us posted as if it doesn't work well I will get the Innovate instead of the AEM...
Noob question, both my laptops don't have null modem ports. Could I use a RS232 to USB adapter along with a null model cable to upgrade the firmware on this controller? something like this:
USB to RS232 Serial Null Modem Cable COM DB 9 Pin Lead | eBay
Do you know if this would work with the Autometer Nexus's 0-4v data output feed?
I don't actually have the gauge yet, (want to get matching gauges all around if possible) but from what I've read everywhere it's a 0-4v analog signal for datalogging if that makes a difference. Not sure if it's a data signal or just varying voltage. Perhaps my use of "data" in my original post might be inaccurate to begin with.
analog means its just a varying voltage, you should be good to go
So I was thinking of how to get my car to stop locking and unlocking it's self every time I turn off the car. I know its because of the LCD Boost controller. If I disconnect the wire/s from the ETACS and/or the remote locking system controller from the OBDII plug will it will stop? has anyone tried it?
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
