Autozone and Oreilly's can't check ODBI, I just went the other day and neither had the plugs to do it, so I'll have to go to a dealer and see.
1992 3000GT VR-4
Someone asked for improved turbo spool up so I created "PSI start" and "PSI end". Let's assume 50% duty cycle gives us 15psi and this is our desired boost level. Anything above the 50% duty cycle line will improve the turbo spoolup. In the ideal world we would switch from 100% duty cycle to 50% duty cycle when we reached 15psi, but of course in the real world wastegates can't react that fast and would cause a major boost spike. Instead what we need to do is ramp down to our desired boost level to avoid a boost spike, this way we can enjoy the improved turbo spoolup without any side effects.
On my car I experience some boost loss at high rpms -- probably because I'm still using a stock catback. Here's my settings for compensating the loss:
Duty Cycle OFFSET:
4000 +0
4500 +0.6
5000 +1.3
5500 +2.0
6000 +2.6
6500 +3.3
7000 +4.0
7500 +4.0
8000 +4.0
I currently don't have a CEL light at the moment, I'm waiting for it to return before I can test for it again.
Hey just an update. I used the stock wiring... works great. And there is two less new wires in the engine bay.the ECS button conversion for "push for boost" works great. I love this thing!
www.Chromedecu.org
2 year Warranty on all ECUs.
How To Contact Me:
eMail: apape10@yahoo.com
3SI: Jesters Deadd
www.Chromedecu.org
I just went to the mitsu dealer to have my code checked and spend $86 to learn that it was a front o2 sensor code, which I had suspected seeing how it's cut. So this is definitely something the unit should have read, but it couldn't for some reason.
Looks like I'm late to the party, but this is one of the coolest things I've ever seen. Nice work!
AEM Compatibility please.
R.I.P Spyder you are missed.
93 VR4 453 Hp, balanced, Ported, Polished, Port Matched, 99 lifters, Ross 70 over 8.5 to 1 forged pistons, Stress relieved shotpeened magnafluxed rods,EK2 Red poly motor mounts, Fidanza Adjustable Cam Gears,Kevlar timing belt, Polished Fuel Rails, 16 T, Gutted Precats, 3SX performance down pipe, Race pipe,QTP Exhaust 3" Cutout, HKS Cat Back, MSD Wires, NGK BCP7ES non-resistor plugs, AEM EMS ECU, Speed Density Conversion, AEM 3.5 MAP, AEM AIT,Dual K&N air filters, Dejon Tool Dual Air Intake, Dejon Tool Y Pipe, PTE 550, Walbro fuel pump, EK2 fuel loop, No EGR, Vacuum line reduction, AEM True Flow Controller, Greddy BOV, AEM Gauge UEGO Controller wide band O2 sensor, Gauge-Tech, Kormex tranny,Quadco XR steel Output shaft, LSE Stainless Steel Transfer Main case and Midcase, Quadco input spool, Lightened flywheel, South Bend 6 Puck DXD F Clutch, Greddy EGT, Autometer Boost Gauge, 3SX fuel pressure gauge, Cross Drilled and Slotted Rotors, Ceramic Brake Pads, FMIC , 5Zigen FNO1R-C, Audio: 6 New Infinty speakers. Alpine CDA MP3/WWA 9847 Reciever, 2 Dual 300 watt amps. Cianci 3 gauge A pilars, Aluminum defroster vents' lowered
I have a weird issue with mine. Anytime I go wot it turns off and reboots almost at a certain throttle position. Even if I'm in 6th gear and mash it at 30mph it still does it. I have litteraly checked everything with no faults found. Another is when I go to read or delete codes it freezes until I reboot it. I have a 94 hybrid
Fully Forged, 16G's ect.
