Page 38 of 154 FirstFirst ... 2836373839404888138 ... LastLast
Results 371 to 380 of 1538
  1. #371
    I Kill Threads verified
    Wichita KS
    Yes. (One more character!)
    1992 3000GT VR-4
  2. #372
    Hi,
    Will this unit function as a stand alone boost controller? as it currently does not support my Vi-PEC EMS.
    Cheers,
    Joe
    Boost controller functions with or without ECU connection, so yes. Some advanced boost options will be unavailable if ECU connection is unavailable.
    Also other good news, I have knob acceleration working. Any menu that has large range of digits can take a long time to scroll through, with the knob acceleration it goes through 10x faster. I'll post an update later today.
  3. The Following User Says Thank You to BlackStealth For This Useful Post:
  4. #373
    I like that
    At NG I was spinning that thing like crazy. I didn’t set my over boost protection high enough a couple times and ruined the runs.
    There's is a bit of good in evryone verified
    We need one.
  6. #375
    www.chromedecu.org verified
    DFW
    NIce!
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  7. #376
    Australia verified
    Melbourne, Australia
    Nice work on the updates. I noticed that on my first generation unit it would read my rear O2 sensor, for example at say 0.96V. Now it reads it around 0.04V or similar. Is this normal, have you inversed the way it reads at all?
    Kangaroo
  8. #377
    Quote Originally Posted by GTOX View Post
    I'll look into it.
  9. #378
    Found the bug, but I am unable to verify if it works as both my O2 sensors are recently broken on my car.
    Tell me if it works now:
    http://www.lcdboostcontroller.com/updates/Update213.exe
  10. #379
    Medford OR
    Confirmed.... it works
  11. #380
    OK!
    I am stuck...
    I have everything wired up and ready to run, but the wideband output/input. The instruction do not cover the wiring of this. The wire that came with the lcd controller has one green, and one brown wire for the wideband input. The AEM wideband has a White output(0-5 V), and a Blue output(serial).
    I need to know which one goes where please...
    I also want to double check that #2 on the boost solenoid is the waste gate, and #3 the (center front) out is Y-pipe.
    An accurate, hurried answer will get you my deepest thanks and nothing more!
