Sharing a little DIY on how to replace the cigarette lighter with the lcdbc knob:
1. Remove leather brakeboot. There is a plastic ring on the bottom of it holding it with hooks. Press both sides gently and lift.
2. To remove cigarette lighter; disconnect two small electrical connectors.
3. On the bottom of the cigarette assembly there is a screw-on ring keeping it in place. Screw that out and take out the assembly. Here you can see what it looks like. http://www.3sx.com/store/catalog/sto...ts-17-400l.jpg
4. Pry out the plastic bezel.
5. Out of 0.5 or 1mm sheet metal cut out a ring with about 30mm or so(measure first im not 100% on this)
6. Put the metal ring/coin in place with the plasic bezel in place and mark out where center is. Drill a hole on that mark. about 6-7mm hole.
7. Fixate the rotary knob in the ring.
8. Use silicone to put in both the coin/ring and the plastic bezel.
9. Place 5$ ebay knob and marvel over your OEM looking rotary knob.
