Page 72 of 154 FirstFirst ... 2262707172737482122 ... LastLast
Results 711 to 720 of 1538
  1. #711
    May 2012
    Houston, TX
    You'll need to identify it from the locating tabs on your MAP, I don't remember what the configuration is, but it will be one of these: | pi | wiring-connectors | gm | pigtails | 3-cavity | male | ACDelco TechConnect
    I have the plug for the GM MAP sensor itself - I meant I need to know what to use for the 3pin header on the LCDBC black box where the MAP connects.
    There was no 3pin wiring harness for that in the box o'stuff from Antero.
    Item (A) in the attached picture.
    Thanks!
    James
  2. #712
    Medford OR
    Sorry I misunderstood.... I'll go away now.....
    I know Antero can supply you with that plug... I got mine from him.
  3. #713
    May 2012
    Houston, TX
    LOL no worries, thanks for trying to help.
    If Antero can send one that may be easiest. I'm in no particular hurry. Lots of things to do before the new electroncs go in the car...
  4. #714
    The connector for the external pressure sensor is not normally included as that is a custom request. I do have the necessary parts available, connector & pins. I chopped off the end of my Greddy pressure sensor connector, and replaced it with a new style so it's plug and play. The needs differ from person to person. Some just need a small harness, some want a very long shielded harness. So far only 5% of the LCDBC users use an external sensor. Anyhow send me a PM.
  5. #715
    I'll be sending my materials out to Paul tomorrow so he can do the surgery.
  6. #716
    Pm me pricing please.
    Post via Tapatalk
  7. #717
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Just FYI I used the silicon or whatever was recommended to mount my LCD and after my car sat outside for a week in the sun it looks like the display slide downwards a little. Can still see 95% of the text, but just wanted to give you guys a heads up.
  8. #718
    I used epoxy for that reason. Just need to make sure you get it placed where you want it, and set it up so it does not move till set...
  9. #719
    One fix at a time verified
    Kansas
    I went to wire up my wideband harness as well as a few other things I was doing to the car. For some reason it got changed from MUT but anyways I'm sure it has been covered already I'm trying to datalog the wideband and boost through evoscan. I had the tactrix cable plugged into the OBDII port and the serial cable into the expansion port on the boost controller. It isn't working. I also tried just doing the serial cable with the boost controller hooked up through OBDII but evoscan was not able to connect this way. I tried the settings in the manual for the boost controller but I must be doing something wrong. How can I get evoscan to work with the ecu and the boost controller?
  10. #720
    ok only problem i have found with this is when the inside of the car gets hot the screen messes up and looks burnt
  • History
  • Information
  • Groups
  • Events
  • Resources
