Page 65 of 154 FirstFirst ... 1555636465666775115 ... LastLast
Results 641 to 650 of 1538
  1. #641
    I held the display in a vice with it powered up. I put a small drop of super glue in each corner of the LCD on the black metal part. That way you can have both hands to set the gauge face down on to the LCD and get it aligned perfect.
    Feb 2012
    Westbury, NY
    How about a picture of your finished installation.
  3. #643
    I haven't seen it mentioned anywhere yet, but is there support for the Omni 4 Bar map sensor yet? If not, I can find the scaling for it. I just ordered one since I got a 96+ intake manifold w/the map sensor spot on it.
    The greddy pressure sensor is 4 bar, and I think the Omni pressure sensor uses the exact same scaling (0.5v to 4.5v) to ( -1bar to +3bar). So if it's the same choose Greddy. If it's different I'll add support for it.
  4. #644
    You have to cut the clear plastic piece in back. Here is mine
  5. #645
    Charles Town, WV
    I think it's a different scale. From this thread:
    Omni 4 bar MAP sensor ROM compatibility settings for USDM Evo 8/9 - evolutionm.net
    Volts ??
    0.51 25
    0.90 49
    1.29 70
    1.68 96
    2.07 120
    2.46 144
    2.85 170
    3.24 195
    3.63 255
    I'm not 100% sure what the right hand column equates into; I think it's the value that applies to the boost formula, which would mean the voltage starts at 0.51, but stops at 3.63 instead of 4.5.
    EDIT: Yep, I think that's right. Using the formula ( 0.2369*x-b ), at 255, and 14.7 atmospheric adjustment, I get 45.7095 psi; I think that's all the info you need? I went with the omni since it's plug-and-play directly on the manifold.
  6. #646
    jba: okay I'lll add that in.
  7. #647
    One fix at a time verified
    Kansas
    I got my processor upgrade in the mail today and installed. Installation was easy and at least now it's reading all the correct information from the ECU. I needed a female to female serial null modem cable to update the unit so I hadn't gotten that far yet.
  8. #648
    No fair! I'm always supposed to be 1st. I guess I'll check the mail box
  9. #649
    forgot to check mine as well....
  10. #650
    Kansas
    It's because your car is green. I used to have one of those.
  11. The Following User Says Thank You to TurboSinceBirth For This Useful Post:
