Page 63 of 154 FirstFirst ... 1353616263646573113 ... LastLast
Results 621 to 630 of 1538
  1. #621
    Charles Town, WV
    Can you send me the 2.22 that will unbrick if I flash 2.23 and it doesn't respond? I think I have the old processor but I'm not 100% sure ... I upgraded from the original one but don't know which version I have now.
  2. #622
    I replaced the 2.22 version on lcdboostcontroller.com with the special version that will unbrick. Just redownload v2.22 from there.
  3. #623
    hey blackstealth will the cable needed for evoscan to work work for HHH
    i cant seem to get my ecu to connect to HHH or evoscan is there a setting needed to change?
  4. #624
    The lcdboostcontroller baud rate is set to 57600 baud, so you'll have to adjust evoscan or HHH to accept the higher speed. The "how-to" is in the PDF manual.
  5. #625
    Jan 2012
    Arizona
    Badass product Blackstealth, I sent you a pm for ordering info.
  6. #626
    Jan 2012
    Arizona
    Quote Originally Posted by Alan92RTTT View Post
    Look at it over the steering wheel. After some time staring at the column while stuck for traffic this morning I don't think its got the angle its needs to work. I think the top edge of the display needs to be above the current top of the steering column cover.
    I think its time to go back to plan A.
    EL can be cut. One option for you though is to go the route you are taking and with some fiberglass filler mold the panel so that the angle of the display is at the driver, anyone who is good with fiberglass or bodywork should be able to help.
  7. #627
    Feb 2012
    Westbury, NY
    Talking Several hours to get this first run completed!
    Just finish my test install in a junk yard cluster. It wasn't as easy as I imagined. I think I like the fuller display though.
    Before anybody asks, the cluster is laying back in this picture so the tach needle is floating.
  8. The Following User Says Thank You to tfw a-ok For This Useful Post:
  9. #628
    Looks like a well done installation.
  10. #629
    ~2006
    Pittsburgh, PA/Wheeling, WV
    I looked and couldn't find the which color wire goes to the wide and.. Does it matter? Just gotta get a ring terminal to ground this, wire up the wide and, and put it inthe cluster =) then do my fuel system, fmoc, etc etc lol!
  11. #630
    The WBO2 input and Auxiliary input harness colors varies, so you can't wire it by color. Refer to the PDF installation manual to know which side is for WBO2 input and which is Auxiliary input.
  • History
  • Information
  • Groups
  • Events
  • Resources
