Page 61 of 154 FirstFirst ... 1151596061626371111 ... LastLast
Results 601 to 610 of 1538
  1. #601
    Yea lol at idle it shows -9 but stays at that till i hit boost
  2. #602
    The internal pressure sensor is rated 0 to 36.25psi, but I find it's actually capable of reading -0.9psi to 36.25psi.
  3. #603
    Medford OR
    Quote Originally Posted by Assy View Post
    mine shows -9 for vacuum is that normal?
    As Antero pointed out, that's -0.9 you're seeing. Until you get up to that level or above it will be parked there.
    If you want to read vacuum, get an external map sensor. I'm using the GM 3bar. (which is 3bar total range, so it tops out at around 30psi)
  4. #604
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Is there any way you could make this work with an Evo MAP sensor wired into the ECU? That way I can wire my wideband and MAP sensor into the ECU (less clutter), log everything with the Tactrix cable, but still get boost and AFR on the LCD? That would be awesome if so!
  5. #605
    Medford OR
    Define what you mean by "into the ECU"? do you already have something tied into the EGRT circuit?
    You will get faster response from direct input to the LCDboostcontroller. I had my GM 3bar hooked into the EGRT circuit before I installed this controller, I just left it in place, hijacked the signal wire right at the ECU, and diverted it to the boost controller.
  6. #606
    I have my GM 3bar hooked exactly like you and I didn't see in the manual how to setup the lcdboostcontroller like that. What wire did you connect to the hijacked signal wire from the ECU and were there any settings to change on the lcdboostcontroller?
  7. #607
    www.chromedecu.org verified
    DFW
    The flashed 98/99 ECus can use a evox map and datalog boost throught the map circuit.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  8. #608
    Medford OR
    The setup menu gives the option to pick internal. Greddy 4bar, or GM 3bar.
    I just located the EGRT wire at the back of the ECU, snipped it, and routed it to the input of the boost controller. IIRC the instuctions indicate it's for an external or Greddy sensor, and may not specify GM 3bar, but it's the same input.
  9. #609
    If anyone needs a custom external pressure sensor harness made just contact me on how long of a wire you need and I'll put a connector on it so it will plug right in. Or I can provide a connector with pins and you can build your own harness.
  10. #610
    Madison Heights, Mi
    Install mockup #1
  • History
  • Information
  • Groups
  • Events
  • Resources
