Originally Posted by
BlackStealth
The 98-99 ECU produce twice the fps vs 94-95 ECUs, so that part is normal.
The early LCDboostcontrollers were not calibrated, I made the mistake to assume the factory calibration was okay when my first unit tested fine and assumed the rest of my microprocessors would be identical when I purchased them altogether in a batch. Unfortunately the calibrations vary greatly. After learning this, I calibrated each unit since then, but the first 20 or so are not calibrated. With your calibration off, this will effect the serial port communication speed (or datalogging). In the setup configuration, there's a section called "Calibration=xxx". This allows you to re-adjust the calibration number. Download and run a program called CoolTerm and set this to 57600 baud, set ignore receive errors and connect. CoolTerm will display the serial output from the lcdboostcontroller. Now what you do is keep incrementing the Calibration number until garbage is displayed on the screen, once you've reached there click back until you find the highest stable calibration number, let's assume it is 170. Subtract 6 from our highest stable calibration number, and that is our ideal calibration number (170-6=164).
