Page 46 of 154 FirstFirst ... 3644454647485696146 ... LastLast
Results 451 to 460 of 1538
  1. #451
    I think that's a good idea, but IMO it would be more useful if it reset on a new boost event. I'd think something like 5-6 psi would work pretty well.
    Another clarification question: I'm going to have to start playing with the temperature DC offset. You have it in 30 deg increments. If I add correction to one increment, I'm correcting from that increment and above correct? For example, if i correct 20 deg at -1, I'm pulling it from between 20 and 50 degrees?
    Yup, I could change it from 0.6psi to 5psi as the trigger event. However, the tiny boost graph would then be empty between 0 and 4psi.
    20F = -1 %
    50F = 0 %
    So a temperature of 35F would get -0.5% because that's the correct weighted value for that range.
  2. #452
    Oct 2011
    Las Vegas
    status on the EMS version? itchin' to ditch my gauge pod...
  3. #453
    Quote Originally Posted by vr4 ftw View Post
    EMS version is done. I'm just waiting for a non-rainy weather day to try it out locally.
  4. #454
    20F = -1 %
    50F = 0 %
    Why not just leave peak-boost up until its value is surpassed or explicitly reset by the user? Don't most BC work this way?
    * Evo8 MAF * TD04-16T * Delphi 780cc * FIPK * Full Custom Exhaust * Hotwired Supra FP * Megan CO *
    * GReddy FMIC * Nitto 555's * Avic Z3 * BlackStealths LCD/BC *** All else stock *
  5. #455
    The Panda Not Verified
    Washougal WA/Portland OR
    Quote Originally Posted by Simace View Post
    This!
  6. #456
    Pass Me Another Hooker
    Toledo,Ohio
    also would like this to be added to the ems i will be running, nice clean look no gauges bysides my aem wideband. be nice. can i get a pm on some info to contact u about one of these please
  7. #457
    Quote Originally Posted by 93SlugTT View Post
    IIRC, this box will also display wideband, so why would you need the WBO2 gauge?
  8. #458
    I'll make a new config option for "Automatic peak boost reset=yes/no". This will keep both group of users happy.
    As for the AEM EMS version, I've picked 10 popular logging items and the remaining 9 items are user definable -- allowing you to choose whatever AEM EMS allows you to datalog.
  9. #459
    Oct 2011
    Las Vegas
    ^^so it's good to go? i vant vone!
    if i don't want this thing to control boost, is it just a matter of not plumbing a vacuum hose to the pressure sensor? i ask because i have my EMS controlling boost.
  10. #460
    AB Canada
    hmmm i like the sounds of this
    1991 GTO TT restoration in progress
    watch the progress from the start:
    http://www.3sgto.org/f2/my-complete-...ions-4545.html
