Has anyone tried to datalog using EvoScan (v2.8 here)?
Reason I ask is that I recently got my FTDI USB-Serial cable and gave it a go. I setup the device (Datalog=passthru, etc) as per the Gen 2 manual along with adding the two new ID's to EvoScan (08 and 09). Connection is successful
Here's the EvoScan setup;
It appears only WB02 and Boost are properly logged, the rest is missing. If I take EvoScan as it's setup and use the Tantrix 1.3U cable directly to the ODBII port, it logs correctly (minus the WB02 and Boost obviously.)
Forgot to mention that I'm running version 2.14 on the LCD/Boost Controller.
