Page 3 of 154 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 1538
    -BOOSTTD- verified
    Elko, Nevada, United States
    Interested in this as well. Pm me with more info...
    I Kill Threads verified
    Wichita KS
    That is BAD ASS! Go ahead and pm me too.
    1992 3000GT VR-4
    In for awesomeness
  4. #24
    *waits for full-color led/lcd with rotary readouts.
  5. #25
    Probably the best thing I`ve seen for our cars yet!.
    Can you trigger an output for the knock warning? (I prefer a buzzer to flashing lights).
  6. #26
    I want .
  7. #27
    Iowa City
    Awesome project!
  8. #28
    ~2006
    Pittsburgh, PA/Wheeling, WV
    PM me too! How do you scale the wideband/boost readings or do you need a set voltage per AFR/PSI? I'm also wondering if you can make it buzz.
  9. #29
    After Ceddy brought my attention of MUToverOBD2 protocol on 95-96 DSM, I went ahead and researched this, purchased an ECU and got this protocol to work. I now can do MUToverOBD2, MUT, and OBD1 all from the same box. In short, every model supported. Our 3S cars 96+ will also work in MUToverOBD2 mode interestingly enough.
    That was on my original checklist of things to do, "activate a remote buzzer". I'll have to check the microprocessor and see if there's any unused pins left to implement that wish. The priority of supporting a buzzer fell to low priority because it can already respond to two important things: 1. If there's knock, reduced the boost. 2. For water/alchy users if your fluid level goes low, it can trigger a latch to automatically reduce your boost to a pump gas friendly boost level and stay that way till next power cycle.
    I don't think I understand your question in regards to "How do you scale wideband / Boost..." . It accepts any wideband o2 sensor output wire from 0-5 volts, and you just enter the low and high limits of the AFR and you're done.
    I made a rough draft PDF format manual for it, anyone who's interested can email at blacklight99 at gmail.com and I'll send you a copy.
  10. The Following 2 Users Say Thank You to BlackStealth For This Useful Post:
  11. #30
    your a nut
    1996 GTO, Owner since 2003.
  • History
  • Information
  • Groups
  • Events
  • Resources
