Page 20 of 154 FirstFirst ... 1018192021223070120 ... LastLast
Results 191 to 200 of 1538
  1. #191
    Are these available for sale again yet?
    Jason
    I'd strongly recommend jumping on it when they come available. The customer support is freaking great also.
    Australia verified
    Melbourne, Australia
    ^ Paul did you end up getting the AEM wideband working correctly with this unit? Keep us posted as if it doesn't work well I will get the Innovate instead of the AEM...
    Noob question, both my laptops don't have null modem ports. Could I use a RS232 to USB adapter along with a null model cable to upgrade the firmware on this controller? something like this:
    USB to RS232 Serial Null Modem Cable COM DB 9 Pin Lead | eBay
    Kangaroo
  3. #193
    Quote Originally Posted by GTOX View Post
    Yup any USB to serial adaptor + a null-modem cable (or adapter) will work. Looks good.
  4. #194
    Not yet, my car is down again. It looks like I got in a hurry and didn't tighten my timing tensioner pulley down well enough. It came loose
  5. #195
    DC Metro Area
    Do you know if this would work with the Autometer Nexus's 0-4v data output feed?
  6. #196
    Quote Originally Posted by Vishnu View Post
    data would be misleading. If it actually does output data, then it wont work, his unit responds to voltage only. If the unit outputs a varying voltage that is directly equal to an AFR, then it should work. If it outputs a data signal, then it wont work.
  7. #197
    DC Metro Area
    Quote Originally Posted by tabasco122 View Post
    I don't actually have the gauge yet, (want to get matching gauges all around if possible) but from what I've read everywhere it's a 0-4v analog signal for datalogging if that makes a difference. Not sure if it's a data signal or just varying voltage. Perhaps my use of "data" in my original post might be inaccurate to begin with.
  8. #198
    analog means its just a varying voltage, you should be good to go
  9. #199
    www.chromedecu.org verified
    DFW
    So I was thinking of how to get my car to stop locking and unlocking it's self every time I turn off the car. I know its because of the LCD Boost controller. If I disconnect the wire/s from the ETACS and/or the remote locking system controller from the OBDII plug will it will stop? has anyone tried it?
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
  10. #200
    Quote Originally Posted by Jesters Deadd View Post
    Wow strange behavior. I don't get anything like that (lock / unlock). So if you disconnect the OBD2 connector it stops this behavior?
