OLED inside air vent adapter.
OLED vs LCD screen physical size comparison:
I am certain I will need a new brain to use OLED but I'm loving the yellow.
Sorry, I didn't take any other screen shots. I've combined screens into 4 lines where I could. I haven't modified the main menu to 4 lines yet -- I plan to display external sensor data on there, as I think that is what people would want.
More information per screen so there is less need for scrolling would be awesome. Like both front and rear trims on the same screen and all 4 senors on another screen.
That sounds great!
Would it be possible to replace the power regulator in older units with at beefier one to avoid having a separate power cable for the OLED display?
Is this the dual regulator version that supports the OLED display or should I be looking for a bigger heat sink?
Your purple boxed LCDBC shows 1 voltage regulator with a heatsink, and 1 power transistor for boost solenoid.
I already have a solution for older LCDBC units. Because the OLED requires an adapter to convert 20 pins to a 4 pin wire harness, this is a good place to include a low profile voltage regulator -- problem solved.
