Page 148 of 154 FirstFirst ... 4898138146147148149150 ... LastLast
Results 1,471 to 1,480 of 1538
  1. #1471
    Quote Originally Posted by Unlogic View Post
    Antero is there any particular EGT kit that you recommend for the LCDBC?
    Look for an EGT kit that produces a 0-5v signal, such as the HKS EGT, or Stinger EGT. If you find one that is not supported, I'll add it to the LCDBC software.
  2. The Following 2 Users Say Thank You to BlackStealth For This Useful Post:
  3. #1472
    I noticed the plastic on the DC power jack connector is getting hard and brittle with age and crumble when you press hard between your fingers. I'd suggest everyone to upgrade to this DC power jack, the plastic is more pliable, and the wire gauge that it comes with is more than adequate. $2.09 US shipped. This 2 meter (6 feet) DC power extension cable has two ends, when you cut this cable, leave a couple inches and save the other end for a future project. When I tested my cable, the color was correct, red for positive (inside tip), black for ground (outside tip). You can test this by putting a multi-meter probe on the outside tip and test if there is low resistance between it and the black wire.
  4. #1473
    This morning I spent some time figuring out or solving the annoyance Evoscan has. That is, if you wanted to use the custom 3000GT EFI for our cars, it would disappear when you choose 1g/12pin connector menu option. Anyhow, the problem is solved, and I included the LCDBC's Boost, WBO2, External sensors 1-4 also.
    Download and follow instructions contained inside:
    http://lcdbc.xp3.biz/updates/EvoscanFiles.zip
  5. The Following 2 Users Say Thank You to BlackStealth For This Useful Post:
  6. #1474
    I've got a flash/update list a mile long, Antero.
  7. #1475
    And if that file is already in there just replace it with this file?
  8. #1476
    Yes that is right.
  9. #1477
    Antero-
    I haven't kept up with whether you've altered your original manual to reflect all the improvements you've made.
    Is there a new(er) version for me to DL and print?
    The one I have is a few years old...
  10. #1478
    Version 3.40 -- it's already a bit dated too.
    http://lcdbc.xp3.biz/EBC-Revision3.40.pdf
  11. The Following User Says Thank You to BlackStealth For This Useful Post:
  12. #1479
    Antero,
    If an external Pressure sensor is used, will the LCD display the vacuum? Will it display a - PSI?
  13. #1480
    Yes that is correct.
