When you purchased an old generation LCDBC unit from someone else, it's harder for me to diagnose your problem, as there's been many improvements on the hardware over the years (such as better OBD2/MUT cable, better serial chips, better DB9 connectors, etc).
Adjusting the "ScreenRefresh=" to a low number will update the screen faster than you can read it. However, if you have a ECU communication problem, it will add additional delays as the LCDBC is waiting for a response from the ECU.
It also sounds like static electricity discharge is causing you grief. If your knob is not installed, and you just use it in your hands, you will cause static discharge and that will cause a microprocessor reset, or other strange behavior.
Your old generation LCDBC is obviously not functioning correctly with the list of problems you have given. It might be a good idea to reflash again in case static electricity has corrupted the software on the microprocessor.
