http://www.lcdbc.xp3.biz
Version 3.35 allows you to disable the tune alert.
Thanks !! Now to remember how the hell I update the unit again lol
Sent from my dog n bone
https://youtu.be/GqsOJq1i0ok
Some people are having a challenge on how to unplug the connector correctly, so I made a short video demonstrating.
I've plugged/unplugged this test LCD screen, perhaps over 200 times without accidentally separating a wire from the crimped pin. The trick is not to let one wire do all the work when pulling, instead grab all wires simultaneously by squeezing tightly and then rock the connector back and fourth until it finally disconnects. I suppose a safer method would be to take a small flat head screw driver and pry the connector from the extreme edges where it mates/locks.
Hi blackstealth,
I did the update to disable tuner alert but unit
Now seems very sluggish and laggy throwing up loads of random knock counts. Is there a way to undo a recent update ?
Cheers
I would if I knew how lol
Ah, hmm.
Don't have the link to the site handy...try this:
Find the last version that worked for you - or any other version, I suppose, DL it, and load 'er.
Assuming the above posts indicate you're prolly running 3.35?
Pick one preceding it.![]()
Yes you can go back to any previous version without issue.
