Page 130 of 154 FirstFirst ... 3080120128129130131132140 ... LastLast
Results 1,291 to 1,300 of 1538
  1. #1291
    Jul 2015
    But the only thing im struggling with is connecting to Evoscan, i purchased latest 2.9, i added the 2 items as per Blackstealth instructions and changed the baud rate etc, i have put some screen shots of the error i am getting......Any ideas please. Also mine is a 95/96 GTO TT 2G so not sure if the cable selection is correct in Evoscan as per screenshot. DSC_0010.jpg
  2. #1292
    Jul 2015
    UPDATE. i deleted the 2 new entries BOOST and MYWBO2 from the list and it connected fine and even started to log, so apart from adding those 2 new lines in Evoscan as per Blackstealth PDF datalogging config, is there anything else that i need to do? it seems that when i add those 2 lines there is a conflict with a duplicate so is there one or two that i have to remove? i cannot see one that has the same attributes but i don't really know the software to well.
  3. #1293
    With respect to your Evoscan software error, check to see if there's another entry called Boost. You have the freedom to call it whatever you like.
  4. The Following User Says Thank You to BlackStealth For This Useful Post:
  5. #1294
    Jul 2015
    Just installed new 100PSI oil pressure sensor and wired in into LCDBC and couldnt be happier.....shows actual PSI of oil pressure unlike the OEM gauge and my crappy chinese Dragon gauge, here are some pics taken at the same time, look at the difference on the crappy chinese gauge....anyone wanna buy it...LOL
  6. #1295
    Oct 2011
    Sundsvall, Sweden
    It would be awesome if we could figure out the scaling of the stock oil pressure sender. I wonder if there is any information on it in the service manual. I'll have to take a look!
  7. #1296
    Oct 2011
    Sundsvall, Sweden
    Found no info what so ever in the service manual regarding the output voltage and scaling of the stock oil pressure sender unit...
  8. #1297
    May 2015
    Quote Originally Posted by mazzerman View Post
    what sensor did you go with? an can you show us a pic of it wired up? thanks
  9. #1298
    Jul 2015
    I went for this one, Pressure Transducer or Sender 100 PSI Stainless Steel for Oil Fuel Air Water | eBay and the wiring is straightforward, from the sensor there is red for power black for ground and blue for signal which goes to EXT1 or EXT2 on the LCDBC with the same wiring nearly red to red black to black and blue to the remaining wire (cant remember which one it was) then in the config just choose 100 PSI oil sensor, easiest install iv ever done
  10. #1299
    Jul 2015
    Trust me you dont need a pic of the install its so easy, 3 wires to 3 wires and choose the sensor in the config, all thanks to the great support from Blackstealth as usual. and a big thanks for adding this feature it is something i really needed.
  11. #1300
    Sep 2011
    Kent, United Kingdom (of miserable bastards)
    blackstealth, is there a way to disable the tuner message feature that cuts boost if it thinks my tune is too lean ??
    I run a strong methanol content in my main fuel tank and as such will often see above 12afr at moderate boost. The LCDBC thinks it's too lean and beeps at me saying 'tune too lean' or similar. How can i stop this or disable that feature ?
    Cheers
    Sent from my dog n bone
