When I looked at the spec sheet of the MC33660, it's 99% identical to the OBD2 chip I already used, which isn't good enough for the cars that are having problems. The transistor/resistor circuit has proven to work better than the OBD2 chip, although not 100%. The USB OBD2/MUT is said to work 100%, I just need fastbikes76 to confirm his cable uses the same LM339 chip.
