Page 107 of 154 FirstFirst ... 75797105106107108109117 ... LastLast
Results 1,061 to 1,070 of 1538
  1. #1061
    Quote Originally Posted by fastbikes76 View Post
    4.) Knock..still recording random peaks of 24-28 although no knock warning or reduction in boost as set.
    Elton-
    I had similar problems - looked underneath and discovered a sloppy front carrier, and the rear is borderline.
    Haven't fixed them yet, but I suspect rather strongly they are responsible for my knock, especially because I was experiencing low-rpm/low-load reports.
    When I hammer it in third to check boost, I was getting no more than a count or two at most.
  2. #1062
    Sep 2011
    Kent, United Kingdom (of miserable bastards)
    Elton-
    The knock ONLY shows on the peak recall section but not in the live knock readings. It also doesn't trip the knock alarm which is set to 3 or more, and doesn't show up in evoscan . I suspect it's a glitch in communication rather than knock (phantom or real) ?
  3. #1063
    Ah - I went directly to the real-time display to suss mine when I was bumping duty-cycle to raise boost.
    That was when I noticed the lack of correlation to what the car was actually doing, relative to load.
    In anticipation of a third-gear pull, I would gently roll up through 1st, then 2nd, and out of nowhere, I would watch it hit 4, or 6, 8, 12, 14...didn't tumble to the mismatch until, out of the blue, I banged a 28, which is the limit the ECU will report.
    Paranoia is required, with these cars, but the no/low-knock 3rd-gear pulls tell the story, I think.
    I'll watch for further developments from you.
  4. #1064
    Oct 2011
    Sundsvall, Sweden
    3.) Connection..still dropping out although not tried the update yet. Will hopefully do it tonight , or wait until unlogic reports back on his lol
    I bought a ferrite core after work but then the weather went bad so I decided to keep the car in the garage today. I'll have go at this tomorrow instead.
  5. #1065
    Sep 2011
    Quote Originally Posted by Unlogic View Post
    Damn.... I had too google that lol. I have no idea with this sort of thing so im a bit like a sheep following the pack. Hell I don't even know how to do the update so that's why I was waiting too see if it cured yours first
  6. #1066
    When you download the update, it has instructions inside.
    The good news is the boxed version LCDBC now defaults to the 2nd serial port (datalogging port), so you don't have to hold down the rotary encoder button anymore during power up. There's no need to worry about screwing up an update, cuz if it does screw up, it lets you reflash as often you like. So no brick scenario.
  7. #1067
    Oct 2011
    Sundsvall, Sweden
    I've been trying to flash my LCDBC with firmware version 3.11 for two hours now using a FTDI based USB-Serial adapter (this one to be precise).
    When I start the flashing program and turn on the LCDBC the screen on the LCDBC goes blank after a few seconds and I get the following messages in the console:
    C:\Users\Unlogic\Downloads\UPDATE311>avrdude.exe -F -v -pm644p -cstk500v1 -P\\.\COM7 -b38400 -D -Uflash:w:"C:\Users\Unlo
    gic\Downloads\UPDATE311\FIRMWARE311_20mhz.hex":i
    avrdude.exe: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
    Copyright (c) 2000-2005 Brian Dean, BDMICRO MAVRIC ATmega128 AVR Microcontroller Boards, Relays, and Optoisolators
    System wide configuration file is "C:\Users\Unlogic\Downloads\UPDATE311\avrdude.conf "
    Using Port : \\.\COM7
    Using Programmer : stk500v1
    Overriding Baud Rate : 38400
    avrdude.exe: stk500_getsync(): not in sync: resp=0x00
    avrdude.exe: stk500_disable(): protocol error, expect=0x14, resp=0x51
    avrdude.exe done. Thank you.
    If I try to run the flash program again while the screen is blank on the LCDBC I get this message instead:
    avrdude.exe: stk500_getsync(): not in sync: resp=0x30
    Once I got this message but I never managed to get this far again afterwards:
    AVR Part : ATMEGA644P
    Chip Erase delay : 9000 us
    PAGEL : PD7
    BS2 : PA0
    RESET disposition : dedicated
    RETRY pulse : SCK
    serial program mode : yes
    parallel program mode : yes
    Timeout : 200
    StabDelay : 100
    CmdexeDelay : 25
    SyncLoops : 32
    ByteDelay : 0
    PollIndex : 3
    PollValue : 0x53
    Memory Detail :
    Block Poll Page Polled
    Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
    eeprom 65 10 128 0 no 2048 8 0 9000 9000 0xff 0xff
    flash 33 6 256 0 yes 65536 256 256 4500 4500 0xff 0xff
    lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
    lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
    hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
    efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
    signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
    calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
    Programmer Type : STK500
    Description : Atmel STK500 Version 1.x firmware
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfe
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xe0
    Hardware Version: 16
    Firmware Version: 4417552.4368076
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xe3
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x1e
    Vtarget : 200098120.5 V
    Varef : 268691.6 V
    Oscillator : 1.373 Hz
    SCK period : 51.0 us
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xf0
    avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xa0
    avrdude.exe: stk500_initialize(): (a) protocol error, expect=0x14, resp=0xe0
    avrdude.exe: initialization failed, rc=-1
    avrdude.exe: AVR device initialized and ready to accept instructions
    Reading | | 0% 0.00s
    avrdude.exe: stk500_read_sig_bytes(): (a) protocol error, expect=0x14, resp=0xe1
    avrdude.exe: error reading signature data for part "ATMEGA644P", rc=-2
    avrdude.exe: error reading signature data, rc=-1
    avrdude.exe: stk500_disable(): protocol error, expect=0x14, resp=0x00
    Got any ideas what I could be doing wrong?
    I'm using a HP Elitebook 2740p with Win7 x64.
  8. #1068
    Oct 2011
    Sundsvall, Sweden
    After quite a few flash attempts the display on my unit has started to fade a few seconds after powering it on until nothing is visible on the display
    Here is a video:
    Cycling the power of the unit brings the display back for a few seconds again before it starts to fade again.
  9. #1069
    Unlogic: In regards to flashing, when the LCDBC first powers on, it checks to see if an updated flash file is available. If more than 2 second passes by it exits and runs the normal LCDBC software. So when you flash, timing is critical to get started. On the PC Side, when you see the black DOS window, power up the LCDBC. If you mess up, you have to wait for the black DOS window to close on its own.
    Also when you see your screen fade like that, the +5v voltage regulator is not doing it's job. Are you able to solder a new LM7805 voltage regulator on it?
  10. #1070
    Oct 2011
    Sundsvall, Sweden
    I must have tried to flash it 100 times last night trying all sorts of timing combinations. I suspect that the dimming of the display issue could be related to the inability to flash cause the problem only started after a few flashing attempts.
    Soldering on a new voltage regulator is no problem, can I replace it with a Texas Instrument UA7805?
    I also tried logging via CoolTerm but as soon as I connect the serial cable the screen starts to fade very quickly (even quicker than on the video I posted). I'll rip out the board and double check all the solder points today.
