HI,
Just fitted this lovely bit of kit and im very impressed with it !! I do however have a few teething issues I need your advice on please
1.) boost control
The car makes the required boost fine, BUT it cycles very badly when building boost in higher gears like 3rd onwards, its almost as if i'm lifting on and off the gas constantly. I am using the Mac valve as recommended and have the connections the correct way around going from Google.
2.) Screen
The screen refresh rate seems very slow on mine and I have had to drop it too its lowest setting of 2 to actually get 'live time' information. It also sometimes slows down so bad that if I turn the dial it can take upto 2 seconds to change to next menu.
3.) connection
The car connects perfectly something and then will drop out and attempt to reconnect 4 times randomly for no reason. Once its dropped out it wont actually connect again until car is restarted. Having checked all the settings I am happy they are correct for my car...saying that Evoscan used to do something similar before too so perhaps this is more of a car issue ?
4.) Knock
The screen with the WB, BAR and Knock registers no knock and the audible alarm is set to 5, however if I go to the peak memory showing BAR and Knock it records 28 counts of knock. I know 100% fact its not knocking as I'm running 30% methanol and usually 1.1bar, today I was testing at only 0.75 and recalling a peak of 28counts. No audible warning and no live count of knock shown ?
The car in question is a 97 JDM GTO SR which uses the exact same ECU as your federal spec 3 plug ecu's.
Any help would be greatly appreciated.
