Page 104 of 154 FirstFirst ... 45494102103104105106114 ... LastLast
Results 1,031 to 1,040 of 1538
  1. #1031
    Jun 2011
    Sweden, Gothenburg
    I this is mounted on top of the steering column, what does it block from your view?
    maybe the steeringwheel controls could be a good place for it. It seems to be about the same size as the box.
    http://www.3si.org/forum/attachments...-p8250066a.jpg
  2. #1032
    One fix at a time verified
    Kansas
    Quote Originally Posted by Ange View Post
    Too low. I wouldn't want to look that far down to see what's going on. I like having mine in the tach and mounting it on the steering column would give you excellent visibility. I had my Scanmaster setup that way.
  3. #1033
    The wiring wouldn't work ether
    Sep 2011
    Kent, United Kingdom (of miserable bastards)
    Pm sent !!
    8-)
  5. #1035
    Good spot Elton
    Sent from my GT-I9305 using Tapatalk 4 Beta
  6. #1036
    Oct 2011
    Sundsvall, Sweden
    PM sent!
  7. #1037
    Feb 2011
    Scottsbluff, NE
    If anyone wants the old version (never installed) I will be selling mine to ugrade to the box version. PM me for info.
    1995 Dodge Stealth R/T Turbo
  8. #1038
    Anyone that wants one, send me a private message. Only 10 available.
    And yes the plastic case was done on the 3D printer.
    What does it block if mounted on the steering column? High beam indicator. I don't recall what the other ones beside it are.
    what is the height of this all in one box?
  9. #1039
    Question:
    I have the audio alarm levels for temp and knock set at 235 and 10, respectively.
    Overboost is no longer an issue.
    I'm boosting less than 13psi, knock doesn't report more than 6-7 counts, and temp is not a problem, yet I get the audible alarm as boost builds, around 5K rpm.
    What's up with that?
  10. #1040
    Height is approx 38mm.
    When your alarm sounds, have you checked the screen to see what is being reported? It will flash momentarily the offender, ie, knock, coolant temperature, or overboost.
