Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Little help...
    I'm Kind Of A Big Deal
    Quote Originally Posted by peterkottemann View Post
    yes, leaking caps unfortunately. everything was reconnected correctly, some electronics that were previously inoperable now work and my radio is picking up stations from 150 miles away now. I'll be tearingmy ecu open this week. I figure even if I screw something up I'm no worse off...
    if you totally botch it, then any place that offers rebuilt ECU's won't credit you the core charge since your core is not rebuildable.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    When you getter running, you "WILL" want to do the water pump and timing belt...
    5 yrs is a long time to sit for these parts.
    May 2011
    Metairie, LA
    already have the water pump and new timing belt ready to install. I'm not worried about botching it, I guess I'm more worried about what else I'm going to find when I do get it running as it has been sitting. I'm tempted to pull the engine and do a full on rebuild, I really should pull the engine and check everything out. The guy i bought it from was a used car salesman in the worst way, tried to feed me a line of bull about how it was worth 3 times what i paid for it even though it wasn't running. he put a nice yellow paint job directly on top of the danube that was already there with no primer in the meantime... i bought it as a restoration project more than anything.
    May 2011
    Metairie, LA
    Yeah, thanks for all the help guys, I have confirmed, motherboard in ECU is fried. I am going to use the service manual to backtrack all of the circuits on the board and create a detailed post of it, I would strongly suggest that anyone with a 3S have someone swap out their capacitors before they go bad... when they go, it gets really messy. I'm just hoping it can be salvaged at this point.
    May 2011
    Metairie, LA
    confirmed, cannot even get it credited for a core charge. I've got 6' of niobium-titanium, a type 2 superconductor, let's see if I can repair the irrepairable...
    Are you building a bench top particle collider?
    May 2011
    Metairie, LA
    no, actually i was thinking more along the lines of a small scale uranium enrichment facility... lol
    no, its just a piece of scrap i had been using as a jumper at work, i figure if you're worried about putting too much current through a conductor, get a better conductor. its 50/50/90 rule.
  8. #18
    hey if you need replacement caps i will send you a set for cost of shipping since i bought some i got like 10 of each
  9. #19
    May 2011
    Metairie, LA
    okay, are they the OEM rubycon caps?
