Results 1 to 8 of 8
Thread: different ways to bypass clutch safety switch?
    94 3500gt vr2? verified Feedback Score 9 (100%) n2nsanity's Avatar
    NC
    i just did a 5spd conversion.
    i also replaced the engine harness
    i was thinking this would take care of the clutch switch issue, but that is part of the body harness
    the atx neutral safety switch connector isn't there, so that's not an option
    is there another way to do this?
    __________________________________________________
    -Driftus Maximus- Not Verified Feedback Score 1 (100%)
    Corunna, IN
    I just unplugged the clutch switch on mine but is a factory 5sp. Now I can start it without pressing the clutch pedal.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
    NC
    i have the mtx engine harness swapped in, but still have the atx body harness
    also, mtx ecu in
    maybe its because of something else?
    The one. The only. verified Feedback Score 14 (100%) stealthee's Avatar
    ATX and MTX have the same ECU
    NC
    one of the reasons for swapping the harness and ecu was to go from ca spec to fed spec
    that and the harness was all hacked up
    seemed like a good idea
    now wishing i would have did the atx swap and then tested before messing with the wire harness
    theres like 500 connectors to remember to connect lol
    2 of them i'm stuck on already on top of the clutch safety switch issue
    milkman said something about just disconnecting the clutch switch connector at the pedal and he could start without the clutch depressed
    if that's the case, then it shouldnt be an issue for me, just need to get everything connected properly
    is this right?
    Thermal Engineer- Mmbr Since:8/2005 verified Feedback Score 0 Alex3000gt's Avatar
    Ann Arbor, MI
    Do you still have the connector under the hood that plugged into the auto trans? How did you wire up reverse lights? Reverse lights are on the same auto trans plug as the neutral switch wires.
    '92 3000GT Base ATX converted to MTX - Parted Out
    '91 Stealth ES MTX - Fastest NA FWD at NG11 Drags - SOLD
    '91 Stealth RT/TT Check out my blog
    '10 Jetta TDI MTX - 6 speed: 50MPG Highway
    Rest In Peace, My Brother SGT. R. Evans Taylor: Apr 23 '83 - Oct 14 '11
    NC
    Quote Originally Posted by Alex3000gt View Post
    Swapped atx harness for the mtx harness, so i don't have that atx plug any more, and i just used the reverse light connector from the mtx harness
    I'm just hoping to verify that I shouldn't need the clutch switch before I go putting everything back together.
    Ann Arbor, MI
    Ah, so the car is not back together yet?
    Look at the wiring diagram for the auto and see where the neutral switch goes back to the ECU. These wires need to be crossed.
