Results 1 to 4 of 4
Thread: Puller to pusher (Cooling Fan)
    Some fans can be used as a puller or a pusher fan and i have this fan that is supposed to be "reversible".
    To use it as a pusher fan I should swap the Blades AND polarity of the wiring and it becomes a pusher fan ? Or only the wiring ?
    I have tested both methods but I didn't notice any difference.
    it looks like this
    Forum User Feedback Score 0 box's Avatar
    Jan 2011
    switch polarity. Use a bit of paper to check for suck/blow
    I swapped the Blades and polarity of the wiring I think it works better this way than only switch polarity..
    Yup. The blades are designed to flow a certain direction.
