Results 1 to 10 of 24
Thread: The List-of-things-I-have-to-do-before-NG Thread.
    Forum User Not Verified Feedback Score 0 Keyan's Avatar
    Post 'em up!
    Personally, I have to:
    1) Order new tires (done this morning)
    2) Receive / Install Billet Transfer Case
    3) Install Quadco Output shaft
    4) Install 3SX Poly Bushings
    5) Alignment
    Forum User verified Feedback Score 0 Caswell239's Avatar
    AB Canada
    Which poly bushings did you get all or just some?
    1991 GTO TT restoration in progress
    watch the progress from the start:
    http://www.3sgto.org/f2/my-complete-...ions-4545.html
    just the suspension kit. Package A or something like that
    Southernmost 3S Owner supporter Feedback Score 0 93STLTH's Avatar
    Key Largo, FL
    Man... do I have a list.
    1. Install R/T body pieces. I've got a front 1st gen bumper, 2nd gen rear bumper and 1st gen side skirts and door caps. This includes having to do the wiring for the RT tail lights.
    2. Borla dual exhaust
    3. Addco sway bars
    4. New dash gauges
    5. Refinish a front lip I've been working on
    6. Touch up a few paint chips I have
    7. Drop the car off at the body shop to have the new pieces buffed
    8. Detail the car in and out
    9. Oil change
    I'm sure there's more I'm forgetting. Fortunately, After my shift on Monday, I'm off for two weeks. I should be able to knock all this out.
    2013 NG: 1st place, FWD Drags
    Forum User Feedback Score 0 JasonY's Avatar
    Delaware
    1pc CFDS, JDM gears, LW flywheel and new clutch...
    Jason
    No Show NG11 Not Verified Feedback Score 0 TwoXist's Avatar
    Mesa, AZ
    1. Sand and re-paint trim.
    2. Install front struts
    3. Install new tranny mount.
    4. New tires
    Your 1993 Mitsubishi 3000GT SL is one of 4310 that received VIN numbers. Based on the order of the serial numbers, your car was the 2685th out of the 4310 that were made that year.
    Houston
    1.) Install Billet Tcase and 300m Output Shaft
    2.) Wire Up Fans
    3.) Install Rear Brakes and SSB lines all the way around
    4.) Weld in Throttle Stopper
    5.) Reinstall Seats, Glovebox, and door panels
    6.) Start and Tune on E85
    -David
    11 sec FWD! (old name: 94atxvr2) Feedback Score 0 11secondFWD's Avatar
    2004 ****Click my home page for videos*****
    Toledo OH
    Install my 3 port solenoid and get my boost setup for power braking/launch and the rest of the track.
    Weld a vband on my o2 housing to run an external gate.
    Remove any weight I can.
    and maybe if I get the cash get a 10pt roll cage.
    Then when I arrive I am going to change all the fluids, engine oil, tcase, rear end, tranny, spark plugs
    I am shooting for very low 10s or really anything better than my 10.6@127.9 really.
    For the Vr4 I am going to change oil, tranny, tcase, and rear end fluids. And try to button it up to make it look a little better..
    -Driftus Maximus- Not Verified Feedback Score 1 (100%)
    Corunna, IN
    1. Tie rod ends
    2. Wing risers
    3. Clean inside and out
    4. Find the money to do it all! Lol
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
    Oct 2010
    Oshkosh,WI
    1. Pull bad motor.
    2. Put in good motor.
    3. ??????
