Went a racin on Tuesday!
The track was dry all day, sun broke through around 10:30, temperature was 65, it was superb. The turnout was very small, around 20 cars, meant for TONS of track time.
I recently put new brakes on the car, they are Supercar Engineering's WIDE rotors. They are stock diameter and still use stock calipers, but they are 5mm wider and 2 pc, the center hat is aluminum and this all helps dissipate and handle more heat. Literally, I could not believe how well they performed. I thought I was using enough pedal pressure last year, I wasnt getting into the ABS though. Yesterday it felt like I dropped a 5 ton anchor out the hatch, I couldnt believe the stopping power the car had. I seriously was screaming out loud at how awesome they were. They didnt fade a lick, I lapped for 180 miles and the rotors hardly even wore (the pads sure did though, lol).
Ok, onto the pictures.
All ready to go!
Showed up at the track, unloaded, ready to rock.
This is what my tires looked like after the first session. The outside 1/3 of the tire had some previous camber/toe wear so they may have worn evenly at the track, but wear was not even to begin with.
This is what they looked like at the end of the day. Lol
SCE's insane brakes
Other cars that showed up
Yes, a 2008 GT2
This guy lost a clutch (dual clutch trans) lost all even gears.
