So car's been overheating lately.. Runs cool the majority of the time except on interstate.
At first it was pretty bad cause once it started overheating it didn't stop getting hotter, until i turned the car off and let the car cool down.
so then I hardwired my fans, changed the thermostat. so now it stays cool as long as i stay off the interstate. even when i drive it really hard it stays cool. doesn't make sense....but it doesn't overheat near as much when it does overheat, it just goes a few marks over where it normally goes. so doesn't do it too bad, and it usually ends up going back down.
I also did a full Radiator Flush running a 50\50 mix, and i have a brand new water pump.
anyways I've come to the conclusion my radiator is probably time to get the boot.
So here's my options.
1: Rebuild radiator... I know a shop that does it really good, and this is the cheapest.
2: Junkyard radiator
3: Stock Replacement
4: Aftermarket Replacement.
Obviously 4 is my choice so my question is..
I want a direct fit all aluminum radiator. which would you guys recommend? I do alot of daily driving, but at the same time alot of spirited just cause driving, and I do track days (road course not Drag) so what would you recommend I want Direct fit, not universal. also would you recommend aftermarket fans or do you think the stock ones will do for now?
