Results 1 to 10 of 20
Thread: nitrous issues
    nitrous issues
    So my desire to keep my N/A, N/A has died. this is due to me becoming use to my bolt on 6g74..... i want that new rush of getting a little more power so i went out and purchased nitrous!
    here is what i have for now:
    zex efi wet kit
    zex bottle heater
    zex no2 guage
    zex single purge
    3sx inline fuel presure gauge
    EGT guage (have not purchased yet)
    Im getting ready to put this bad boy on but i have run into a few hurdles
    1.) do i mount the t fitting that goes into the stock fuel line before or after the fpr?
    2.)the zex kit i purchased comes with a managment unit with a sensor for tps. how would i go about splicing this in to our tps on the throttle body?
    3.)the smallest jet the system came with is a 55hp shot. will this overrun our stock fuel system? will a new pump be neccesary? if not what is the largest i can go without having any real issues? Please keep in mind my car has a 6g74 in it currently which is already putting more stress on the 160k NA fuel pump
    4.)i hear alot of people saying to run dry becuase of pooling issues with our plenum, then i hear others say wet will be fine? im i totaly screwed or should i just look into not running over a certain shot?
    5.) since the kit does have a tps sensor this basicaly replaces a wot switch correct? Should i also look into a window switch as well or is that a bit over kill?
    hopefully i put together a well kit so far i have heard good things about zex, let me know if there are any additional iteims i should add to get the maxium safe enjoyment out of this system
    Sorry about the long read as well
    -jesse
    Motor: 3.5 6g74, 3sx lw pulley, Maximal solid mounts, 8.5mm msd wires, Big tyla ground wires
    Drive Train: Spec stage 2, Rps lightweight flywheel
    Fuel: Ohhnoo ss fuel loop, TT fuel pump, TT fuel pump assembly
    Nitrous: Zex Wet EFI Nitrous Kit, zex bottle heater, Zex purge kit, Zex no2 gauge, Nos window switch, Weevil custom ashtray nitrous switch panel
    Managment: Autometer A/F gauge, Hand Held Halo dataloger, 3sx in bay fuel pressure gauge
    Suspension: Front and rear ultimate performance strut bars, Megan springs, Saleen wheels
    Intake/Exhaust: Generic cone filter intake and arm, Ultimate performance intake box, 3sx downpipe, 3sx test pipe, Megan catback
    look Good: 3sx plug cover, 3sx engine covers, Polished plenum, Polished valve covers, Polished fuel rails, 3KGT2NV allen bolt ss kit, 2g black garnish, Rear active aero transplant, Jdm snake eyes
    Interior: Custom two tone leather, Pioneer dvd, Alpine speakers, Alpine 4way amp, Ultimate performance door sills, Razo shift knob, 3sx Aluminum Pedal Covers, dual piller pod
    wasting my money on a NA since 2009
    Before the fpr, if you mount it after you will just be sending it back to your tank.
  3. The Following User Says Thank You to mb3000 For This Useful Post:
  4. #3
    thank you, not sure why that logic escaped my head but it did plus rep for you sir
  5. #4
    any other input? really would like to get a little more information out of this
    Corunna, IN
    My buddy and I put a Zex kit on his Alero. Was really easy. Hooked up the "armed" switch and the WOT switch. Picked up fuel from the fuel rail and plumbed the nozzle into the intake tube. He used the 55hp shot on the stock motor and never had an issue. I was told that the 10lb. bottle will last about 3 weeks with all the "playing" he was doing.
    '92 Stealth ES
    '95 Stealth R/T
    '93 3000GT VR4
  7. The Following User Says Thank You to Nationalmilkman For This Useful Post:
  8. #6
    Advanced Tech? verified
    Quote Originally Posted by Nationalmilkman View Post
    Once you hit 5lbs or so, you will find it difficult to maintain bottle pressure. The electric bottle heaters don't do jack at that point, you will either need a propane torch directly on the bottle, or get a pot of boiling water.
  9. #7
    My kit uses Zex components and I am very happy with them so far. Felt they were a good value.
    As far as your fuel pump, with as easy as the fuel pump is to change on these cars and as cheap as stock TT pumps/Walbros are I would definitely recommend upgrading.
    Not worth doing major damage.
    I use a window switch and really think any extra safety device you can add would be a good idea. After all you went through all the trouble of the engine swap, why risk it.
    I have an MSD window switch and have never had a problem with it. Hooks up to these engines easily and accurately.
  10. The Following User Says Thank You to 92EuroDiamante For This Useful Post:
  11. #8
    i guess i will be browsing the classifieds for a pump. it is my understanding that you dont need to hotwire a tt pump? but you do a walbro/denso? what is the flow rated for a tt pump? is it more then adquate for lets say a 75wet shot or should i look into a walbro or denso?
  12. #9
    A tt pump in proper working order will be fine with a 75hp shot.
    I have run a 75hp shot, along with all major NA mods on just a TT pump and had plenty of fuel.
  13. #10
    Quote Originally Posted by 92EuroDiamante View Post
    hotwired or stock? also where you running a wet shot? bought this kit with safty in mind vs buying dry but with all the talk of pooling fuel in the plenum ive heard im getting kind of scared to actually run it
