Originally Posted by
Chatzvr4
Assumed tank mounting location? Rear Hatch passenger Side
Power requirements and mounting location for pump? 12V switched ignition
Heat exchanger mounting location? In place of an FMIC fills mouth of any 3s bumper
Kit weight?
Overal weight at full fluid capacity (water)? Depends if you run the ice box which is not necessary for street use
Efficiency rating? 20% cooler without ice box (street driving in traffic)
Boost drop and turbo lag/spool as compared to air to air? (less then .5 psi drop)
Weight comparison vs. Air to Air FMIC? (12 lbs heavier due to water without ice box)
