Results 1 to 9 of 9
Thread: TOC TOC! Engine Knock inside with video! Help me diagnose it.
    Pisa, Italy, Italy
    Hi,
    I hope this is my lucky day and I hope this isn't rod knock.. but i don't know yet..
    The story:
    After some laps at VARANO race track in Italy I looked to my oil temp gauge and I have seen a 320F value.. immediately lift the gas and gone out.
    The car doesn'idle well and with that temp at idle the oil press was low and the light ON! I have immediately turned off the car and waited at least 30mins before start up again. At that point NO KNOCK!.. when I was in the track I had NO knock. At the new start up the oil press was fine but the knock was present.
    The oil is Motul 300V competition 15 w 50 with very low miles (max 500).
    Here the video:
    comments?
    Forum User verified Feedback Score 4 (100%) Frostedbutts's Avatar
    Sounds like knock to me, giving me flashbacks
    Williamsport
    ack that sounds exactly like my friends 4 runner. We were dumb and said no way its rods cause it is kinda intermittent like yours. 10 miles later it seized when one of the rod caps busted off and caused real havoc. My guess is rods, ill never forget that sounds. Sorry bud
    Member verified Feedback Score 1 (100%) aaronatstate's Avatar
    July 2005
    Rogers, AR
    Rod knock, time for a rebuild.
    My guess is the same as the above.
    Ft. Lauderdale, FL
    If it's coming from the top of the engine it could be really bad misfiring. Pull one plug wire at a time (or turn off injectors with mmcd - much better idea) to make sure the idle gets worse. If you pull one or two wires and nothing happens, it could be the wires, plugs, coils, or ptu. It does sound a little more mechanical though. If it is clearly coming from the oil pan area it is probably rod knock.
    Pisa, Italy, Italy
    Rod knock cyclinder #2 . F**k!
    Current mods: 13G (stock for my european 3S) - custom dual exhaust - 560 injectors (M20 fuel)- Hotwired 255 Walbro - S-AFC II - Magnecor wires - XTD stage III clutch - BCPR7ES plugs - Kn filter - Blitz DSBC- 19" OZ Superleggera wheels with 225/40 - D2 coilovers - . Gauges: Oil press, oil temp, boost, water temp, front and rear egt, a/f meter, ac complete delete
    Forum User verified Feedback Score 0 Caswell239's Avatar
    AB Canada
    check out my *strange noise* threads, theres links to about 6 diff videos all sounding just like yours. and heres a picture of what it developed into
    sorry to say but i think your done. pull the pan and check for loose Caps. My cap obviously loosened off and then finally fell off
    1991 GTO TT restoration in progress
    watch the progress from the start:
    http://www.3sgto.org/f2/my-complete-...ions-4545.html
    Pisa, Italy, Italy
    I pulled the pan yesterday night and the damned rod of the cylinder 2 is knocking! now I have to plan a rebuild..
