Results 1 to 6 of 6
Thread: Hatch differences throughout the years???
    I just swapped out my 92 hatch for a 98 hatch because its in a lot better condition but I cannot get the hatch to line up no matter what I try. I have a larger gap on one side than the other and the whole hatch seems raised a little bit away from the body. I have tightened the rubber bumpers all the way in so they don't interfere with the alignment. I swapped the hatch latch with the 92 one because the 98 latch is larger and doesn't fit into the latch catcher thing but I left the latch catcher thing loose so it also would not interfere. I have loosened the hinge brackets on the body and the hatch itself and still no luck. I don't have a lot of experience lining up body panels. What is the best way to go about this or are the 98 hatches slightly different than the 92?
    Learn how to Powder Coat at www.powdercoatguide.com.
    I'm Kind Of A Big Deal
    The hatches are all the same. If either car was hit before, it could throw things out of whack, if the top wasn't lined up properly it will sit awkwardly... etc
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    I cant find any evidence of an accident on the car at all. I took the hatch off, and everything else that could possibly interfere with it lining up, including the hinges and it is still raised up on the driver side and not the passenger side. I think the hatch must be bent so in that case does anyone know how to replace the lower hatch trim around the rear window? It looks like the top one but skinnier and doesn't seem to want to come off without breaking.
    www.chromedecu.org verified
    DFW
    the latches and hooks are different. the 98 hook is longer.
    www.Chromedecu.org
    2 year Warranty on all ECUs.
    How To Contact Me:
    eMail: apape10@yahoo.com
    3SI: Jesters Deadd
    www.Chromedecu.org
    DFW
    I found this out on my 98 SL and 99 VR4. I replaced the hook with a 91-97 hook and the hatch wouldn't close right and always left the hatch light on. I finally realized the differences when I compared my stock 98SL latch with the one I had bought. Long story short, switch your hooks.
    PS. send me the hook from your 98 hatch and I will send you my 91-97 hook that doesn't let my 98SL hatch close properly.
    The latches and hooks were the first thing I tried and no luck.
