So I have the feeling something is broken somewhere based on how the fuel pump in this TT is wired (not my doing).
There is a small wire spliced into the black/blue wire at the fuel pump (power) that is run all the up under the dash and was jammed into the socket for the main engine fuse in the fuse box near the driver's knee. Apparently this is how the pump is being powered and controlled.....they even put in a higher amp fuse (25) to combat the extra load I guess...
So, with this wire disconnected the car will not start. The pump does not appear to be getting power. The black/blue wire is not severed at the pump, it's still wired normally, so if it's not getting power then what's the next culprit? I suppose that wire could have a break in it, but what other relays and switches do I need to be looking for? The fuel pump relay near the MAF? This couldn't have anything to do with the MFI relay could it? Do I need to be listening for that thing to tick or not (is tick good or bad?).
The car is also run by an AEM EMS, they don't have to be wired up or configured specially for the fuel pump to get cut on do they? lol
Any help would be appreciated. One day I'll sort all the mistakes made the previous owner, lol
