Results 1 to 8 of 8
Thread: clutch lines
    94 3500gt vr2? verified Feedback Score 9 (100%) n2nsanity's Avatar
    NC
    clutch lines
    anyone here replace their clutch lines?
    i have a long braided ss line to replace the solid line
    (from the clutch master cylinder to the firewall bracket)
    also have a short braided ss line to replace the rubber line
    (from the firewall to the bracket on the trans)
    was wondering if there is a replacement for the remaining short solid line on the trans (from bracket to slave cylinder)
    or is this not necessary at all?
    also, should i put something on the threads for a better seal, like teflon tape?
    Cazenovia, NY
    No need for Teflon tape. I thought the long SS line replaced everything... including the small damper line on the tranny?
    NC
    got it from a friend
    will have to get more details from him on it
    that'll be nice to have only 1 line instead of 3 segments
    If it is out line then it will go from the master right to the slave, all one peice.
    If its not our line then probably not, I don't think anyone else makes the full line.
    And the list goes on...
    supporter
    Feedback Score 14 (100%) stealthee's Avatar
    Quote Originally Posted by x2xtreme360 View Post
    This.
    Get rid of that POS damper. I ditched mine YEARS ago. I just attached a piece of hard line to the end of my soft line and ran it straight to the slave.
    I do intend to one day get the STM full line, but no point in buying it with the car just sitting in the yard. I may have other plans for it anyway.
    Forum User Not Verified Feedback Score 1 (100%) ntcmpjg's Avatar
    Bamberg, Germany
    It's your line I'm the one who gave it to him.
    3000GT of Europe
    www.3sofeu.org/main
    Cherry Hill Mitsubishi Coupon Code- 3SE
    NC
    nice, 1 line will be much simpler and hopefully look better
    Quote Originally Posted by ntcmpjg View Post
    Ok, the fitting with crush washer goes in the slave cylinder, the other fitting goes in the master without a a washer. No need for teflon tape anywhere. Then basically run the line where the stock one went, or however else will work for you.
